Ir para o conteúdo principal
Epson VS240 Bulb Replacement
O que você precisa
  1. Epson VS240 Bulb Replacement, Bulb: passo 1, imagem 1 %32 Epson VS240 Bulb Replacement, Bulb: passo 1, imagem 2 %32
    • Unplug the device and let it cool for an hour.
    • Place the device on a flat surface.
    Pergunte ao FixBot
    Comentar
  2. Epson VS240 Bulb Replacement: passo 2, imagem 1 %32 Epson VS240 Bulb Replacement: passo 2, imagem 2 %32
    • Using the Phillips #2 screwdriver, loosen the single screw securing the lamp cover.
    • Be careful of broken glass in the case that your bulb has been broken.
    • If there is broken glass, carefully shake the device to get the shards of glass on a piece of paper. Carefully dispose of the paper with the glass shards on it.
    Pergunte ao FixBot
    Comentar
  3. Epson VS240 Bulb Replacement: passo 3, imagem 1 %32 Epson VS240 Bulb Replacement: passo 3, imagem 2 %32
    • Carefully slide the cover and lift it off the device.
    • Again, be careful of any broken parts within the device.
    Pergunte ao FixBot
    Comentar
  4. Epson VS240 Bulb Replacement: passo 4, imagem 1 %32 Epson VS240 Bulb Replacement: passo 4, imagem 2 %32 Epson VS240 Bulb Replacement: passo 4, imagem 3 %32
    • Use the Phillips #2 screwdriver to loosen the screws attaching the bulb to the projector.
    • You only need to loosen the screws since they do not remove from the bulb completely.
    Pergunte ao FixBot
    Comentar
  5. Epson VS240 Bulb Replacement: passo 5, imagem 1 %32 Epson VS240 Bulb Replacement: passo 5, imagem 2 %32
    • Once the bulb has been loosened, grab the raised section of the bulb and carefully lift the bulb up and away from the device.
    Pergunte ao FixBot
    Comentar
Conclusão
Be gentle when inserting the new bulb. If you feel any resistance when inserting the replacement bulb, chances are that you inserted it the wrong way. This is a common mistake. Turn it around, making it face the right direction, before again inserting it into the device.
Be careful when screwing components back into the device since over-screwing can result in damage to the pieces.
Toni Brennan
Membro desde: 09/28/21
121 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 5-3, Hunter Fall 2021 Membro de Clemson, Team 5-3, Hunter Fall 2021
CLEM-HUNTER-F21S5G3
5 Membros
Autoria de 6 guias
1Comentário do guia
I replaced the bulb in the projector, but it still won't operate, and when I removed and reinstalled a bulb in my other projector, it does the same thing now, How do I fix it even with a replacement bulb?
Derrick A Durham - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 617
