Ir para o conteúdo principal
Epson PowerLite 83+ Power Supply Replacement
O que você precisa
  1. Epson PowerLite 83+ Power Supply Replacement, Motherboard: passo 1, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement, Motherboard: passo 1, imagem 2 %32 Epson PowerLite 83+ Power Supply Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
    Pergunte ao FixBot
    Comentar
  2. Epson PowerLite 83+ Power Supply Replacement: passo 2, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 2, imagem 2 %32 Epson PowerLite 83+ Power Supply Replacement: passo 2, imagem 3 %32
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
    Pergunte ao FixBot
    Comentar
  3. Epson PowerLite 83+ Power Supply Replacement: passo 3, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 3, imagem 2 %32
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
    Pergunte ao FixBot
    Comentar
  4. Epson PowerLite 83+ Power Supply Replacement: passo 4, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 4, imagem 2 %32 Epson PowerLite 83+ Power Supply Replacement: passo 4, imagem 3 %32
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
    Pergunte ao FixBot
    Comentar
  5. Epson PowerLite 83+ Power Supply Replacement: passo 5, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 5, imagem 2 %32 Epson PowerLite 83+ Power Supply Replacement: passo 5, imagem 3 %32
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Epson PowerLite 83+ Power Supply Replacement: passo 6, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 6, imagem 2 %32
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
    Pergunte ao FixBot
    Comentar
  7. Epson PowerLite 83+ Power Supply Replacement: passo 7, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 7, imagem 2 %32
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
    Pergunte ao FixBot
    Comentar
  8. Epson PowerLite 83+ Power Supply Replacement, Projector Lens: passo 8, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement, Projector Lens: passo 8, imagem 2 %32 Epson PowerLite 83+ Power Supply Replacement, Projector Lens: passo 8, imagem 3 %32
    • Remove the four 6 mm Phillips #2 screws securing the fan bracket.
    • Remove the fan bracket by pulling straight up and set it aside.
    Pergunte ao FixBot
    Comentar
  9. Epson PowerLite 83+ Power Supply Replacement: passo 9, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 9, imagem 2 %32 Epson PowerLite 83+ Power Supply Replacement: passo 9, imagem 3 %32
    • Remove the four 6 mm Phillips #2 screws securing the projector lens.
    Pergunte ao FixBot
    Comentar
  10. Epson PowerLite 83+ Power Supply Replacement: passo 10, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 10, imagem 2 %32
    • Unhook the JST connector wire from wire stay and move it aside.
    • Remove the projector lens from the base.
    Pergunte ao FixBot
    Comentar
  11. Epson PowerLite 83+ Power Supply Replacement, Power Supply: passo 11, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement, Power Supply: passo 11, imagem 2 %32 Epson PowerLite 83+ Power Supply Replacement, Power Supply: passo 11, imagem 3 %32
    • Remove the sensor using a spudger and lifting it from the bottom.
    Pergunte ao FixBot
    Comentar
  12. Epson PowerLite 83+ Power Supply Replacement: passo 12, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 12, imagem 2 %32
    • Remove the lamp's power plug by rocking towards the fan's vent and then pulling up.
    Pergunte ao FixBot
    Comentar
  13. Epson PowerLite 83+ Power Supply Replacement: passo 13, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 13, imagem 2 %32
    • Remove the three 6 mm Phillips #2 screws securing the power supply.
    • The screw located by the power supply's fan is near a magnetic field. Reinserting this screw can be difficult.
    Pergunte ao FixBot
    Comentar
  14. Epson PowerLite 83+ Power Supply Replacement: passo 14, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 14, imagem 2 %32 Epson PowerLite 83+ Power Supply Replacement: passo 14, imagem 3 %32
    • Remove the two 6 mm Phillips #2 screws securing the wire guide.
    • Remove the wires by gently lifting up the wire guide.
    Pergunte ao FixBot
    Comentar
  15. Epson PowerLite 83+ Power Supply Replacement: passo 15, imagem 1 %32 Epson PowerLite 83+ Power Supply Replacement: passo 15, imagem 2 %32
    • Using your fingers, firmly press in the sides of the power plug while lifting up.
    • Remove the power supply.
    Pergunte ao FixBot
    Comentar
Conclusão
Blake Davis
Membro desde: 02/22/22
181 Reputação
Autoria de 1 guia
Equipe
Clemson, Team 2-4, Hunter Spring 2022 Membro de Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 17
Ao todo: 358
