Ir para o conteúdo principal
Epson PowerLite 83+ Fan Replacement
O que você precisa
  1. Epson PowerLite 83+ Fan Replacement, Motherboard: passo 1, imagem 1 %32 Epson PowerLite 83+ Fan Replacement, Motherboard: passo 1, imagem 2 %32 Epson PowerLite 83+ Fan Replacement, Motherboard: passo 1, imagem 3 %32
    • Remove the eight 5mm Phillips #2 screws securing the projector's bottom cover.
    • A long shank Phillips #2 screwdriver is required to reach the screws.
    Pergunte ao FixBot
    Comentar
  2. Epson PowerLite 83+ Fan Replacement: passo 2, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 2, imagem 2 %32 Epson PowerLite 83+ Fan Replacement: passo 2, imagem 3 %32
    • Flip the projector over and lift the top cover from the rear of the projector.
    • Two cables are connected at the front that prevent full removal.
    • Disconnect the slide cover JST connector. Grip the connector and rock it back and forth while apply gentle pressure.
    Pergunte ao FixBot
    Comentar
  3. Epson PowerLite 83+ Fan Replacement: passo 3, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 3, imagem 2 %32
    • Using a spudger, lift the ribbon cable's locking tab along the length of the cable.
    • Remove the ribbon cable from the connector and place the projector's top cover aside.
    Pergunte ao FixBot
    Comentar
  4. Epson PowerLite 83+ Fan Replacement: passo 4, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 4, imagem 2 %32 Epson PowerLite 83+ Fan Replacement: passo 4, imagem 3 %32
    • Remove the two 6 mm Phillips #2 screws.
    • Remove the single silver 5 mm Phillips #2 screw.
    Pergunte ao FixBot
    Comentar
  5. Epson PowerLite 83+ Fan Replacement: passo 5, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 5, imagem 2 %32 Epson PowerLite 83+ Fan Replacement: passo 5, imagem 3 %32
    • Using your fingernails or a spudger, remove the eleven JST connectors attached to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Epson PowerLite 83+ Fan Replacement: passo 6, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 6, imagem 2 %32
    • Using a spudger, flip up the plastic locking tabs and gently remove the three ribbon cables from their connectors.
    Pergunte ao FixBot
    Comentar
  7. Epson PowerLite 83+ Fan Replacement: passo 7, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 7, imagem 2 %32
    • Ensure all JST connectors are clear of the motherboard and that the ribbon cables freely move in their motherboard cutouts.
    • Lift the motherboard from the front side of the projector to clear the ribbon cables.
    • Disconnect the speaker's JST connector on the underside of the motherboard using your fingernails.
    • Remove the motherboard from the case.
    Pergunte ao FixBot
    Comentar
  8. Epson PowerLite 83+ Fan Replacement, Exhaust Fan: passo 8, imagem 1 %32 Epson PowerLite 83+ Fan Replacement, Exhaust Fan: passo 8, imagem 2 %32
    • Loosen the two captive Phillips #2 screws securing the lamp.
    • Captive screws should not be removed. They are secured to the lamp itself with retaining rings and will be removed along with the lamp.
    Pergunte ao FixBot
    Comentar
  9. Epson PowerLite 83+ Fan Replacement: passo 9, imagem 1 %32
    • Hold onto the indented areas of the lamp with your fingers and gently pull it upwards to remove it from the casing.
    Pergunte ao FixBot
    Comentar
  10. Epson PowerLite 83+ Fan Replacement: passo 10, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 10, imagem 2 %32 Epson PowerLite 83+ Fan Replacement: passo 10, imagem 3 %32
    • Remove the four 6 mm Phillips #2 screws.
    • Lift the fan bracket straight up to remove it from the casing.
    Pergunte ao FixBot
    Comentar
  11. Epson PowerLite 83+ Fan Replacement: passo 11, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 11, imagem 2 %32
    • A long, thin shank Phillips #2 screwdriver is required to remove the screws.
    Pergunte ao FixBot
    Comentar
  12. Epson PowerLite 83+ Fan Replacement: passo 12, imagem 1 %32 Epson PowerLite 83+ Fan Replacement: passo 12, imagem 2 %32
    • Remove the exhaust fan from the bracket.
    Pergunte ao FixBot
    Comentar
Conclusão
Billy Fox
Membro desde: 02/22/22
467 Reputação
Autoria de 3 guias
Equipe
Clemson, Team 2-4, Hunter Spring 2022 Membro de Clemson, Team 2-4, Hunter Spring 2022
CLEM-HUNTER-S22S2G4
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 25
Ao todo: 550
