Ir para o conteúdo principal
Epson PPC650 Screen Replacement
O que você precisa
    1. Epson PPC650 Screen Replacement, Case: passo 1, imagem 1 %32 Epson PPC650 Screen Replacement, Case: passo 1, imagem 2 %32 Epson PPC650 Screen Replacement, Case: passo 1, imagem 3 %32
      • Locate the silver power button. Gently slide the button to the middle section labeled "off" to shut down the camera.
      • Remove the batteries from the battery compartment located on the underside of the camera.
      • Remove the SD card from the compartment located on the flat, left side of the camera.
      Pergunte ao FixBot
      Comentar
    2. Epson PPC650 Screen Replacement: passo 2, imagem 1 %32
      • Remove the two screws on the rounded side of the camera.
      Pergunte ao FixBot
      Comentar
    3. Epson PPC650 Screen Replacement: passo 3, imagem 1 %32 Epson PPC650 Screen Replacement: passo 3, imagem 2 %32
      • Remove the three screws on the flat side of the camera.
      • All of the silver screws go into the side of the camera that is silver.
      • All of the black screws go into the side of the camera that is black.
      Pergunte ao FixBot
      Comentar
    4. Epson PPC650 Screen Replacement: passo 4, imagem 1 %32
      • Remove the four screws from the bottom of the camera.
      Pergunte ao FixBot
      Comentar
    5. Epson PPC650 Screen Replacement: passo 5, imagem 1 %32 Epson PPC650 Screen Replacement: passo 5, imagem 2 %32 Epson PPC650 Screen Replacement: passo 5, imagem 3 %32
      • Separate the front and the back pieces of the camera's plastic casing using a spudger.
      • WARNING: When pulling the front plastic casing, be careful of the wires that are connected to the aperture control.
      • Use minimal force so that the plastic casing does not break.
      • When separating the small silver siding, the indicator for the view/off/playback may fall out.
      • The plastic viewing window located on the top of the camera may also become lose and fall out.
      Pergunte ao FixBot
      Comentar
    1. Epson PPC650 Screen Replacement, Screen: passo 6, imagem 1 %32 Epson PPC650 Screen Replacement, Screen: passo 6, imagem 2 %32 Epson PPC650 Screen Replacement, Screen: passo 6, imagem 3 %32
      • Remove the copper sheet from the front and back paneling.
      • Use the spudger to unsolder the copper paneling.
      • Use the spudger to separate the back circuit board from the camera.
      Pergunte ao FixBot
      Comentar
    2. Epson PPC650 Screen Replacement: passo 7, imagem 1 %32 Epson PPC650 Screen Replacement: passo 7, imagem 2 %32
      • The picture viewing screen is glued to the backing as well as wired in with pink and white wires.
      • Exert minimal force to pull the screen loose from the camera.
      • Remove the pink and white wiring from the internal paneling. These wires are soldered in.
      • Remove the orange data hookup cable that feeds into the back circuit board.
      Pergunte ao FixBot
      Comentar
      • Once all wires have been detached and the old screen has been removed place the new screen into the camera.
      • Insert data hookup into the back of the camera and into the new screen.
      • Re-solder the new pink and white wire onto the internal circuit board.
      Pergunte ao FixBot
      Comentar
Conclusão
Anne
Membro desde: 02/12/13
107 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-5, Buehl Spring 2013 Membro de Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
4 Membros
Autoria de 30 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 807
