Ir para o conteúdo principal
Epson EX90 Cooling Fan Replacement
O que você precisa
  1. Epson EX90 Cooling Fan Replacement, Cooling Fan: passo 1, imagem 1 %32 Epson EX90 Cooling Fan Replacement, Cooling Fan: passo 1, imagem 2 %32
    • Place the projector so that the bottom side is facing upwards
    • Remove the eight screws pictured from the bottom of the device.
    • Open the cover.
    • Be careful when opening the cover; a ribbon cable is still connecting the cover to the motherboard.
    Pergunte ao FixBot
    Comentar
  2. Epson EX90 Cooling Fan Replacement: passo 2, imagem 1 %32
    • Carefully remove the two parallel wire connectors which connect the fan to the corner of the motherboard.
    • Take care to record the port which each wire comes from, so as not to get your wires crossed.
    Pergunte ao FixBot
    Comentar
  3. Epson EX90 Cooling Fan Replacement: passo 3, imagem 1 %32
    • Remove the three screws pictured, which hold the fan's frame in place.
    Pergunte ao FixBot
    Comentar
  4. Epson EX90 Cooling Fan Replacement: passo 4, imagem 1 %32 Epson EX90 Cooling Fan Replacement: passo 4, imagem 2 %32
    • Remove fan and related assembly from projector.
    • Detach fan from housing.
    • If the fan is still in good condition, use a paper towel or cloth and clean out all the dust on your fan before reassembling.
    Pergunte ao FixBot
    Comentar
Conclusão
Lucas Ketchie
Membro desde: 04/01/22
160 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 447
