Ir para o conteúdo principal
Epomaker Shadow-X Keycap Replacement
O que você precisa
    1. Epomaker Shadow-X Keycap Replacement, Keycap: passo 1, imagem 1 %32
      • Power down the keyboard and unplug any attached cables.
      Pergunte ao FixBot
      Comentar
    2. Epomaker Shadow-X Keycap Replacement: passo 2, imagem 1 %32
      • Place the tool around the keycap, with the prongs on opposite sides of the key.
      • Gently pull the keycap up and off the switch stem.
      • Avoid pulling at an angle to prevent damaging the stem or keycap.
      Pergunte ao FixBot
      Comentar
    3. Epomaker Shadow-X Keycap Replacement: passo 3, imagem 1 %32 Epomaker Shadow-X Keycap Replacement: passo 3, imagem 2 %32 Epomaker Shadow-X Keycap Replacement: passo 3, imagem 3 %32
      • For larger keys, such as the Spacebar, Shift, or Enter, insert the puller evenly on both sides.
      • If using a pry tool, pry the middle first, then evenly on both sides.
      • Lift gently, using tweezers to stabilize any clips if necessary to prevent them from snapping.
      Pergunte ao FixBot
      Comentar
    4. Epomaker Shadow-X Keycap Replacement: passo 4, imagem 1 %32 Epomaker Shadow-X Keycap Replacement: passo 4, imagem 2 %32 Epomaker Shadow-X Keycap Replacement: passo 4, imagem 3 %32
      • Align the new keycaps, positioning the new keycaps over the switch stem, making sure it's centered.
      • Press straight down, applying even pressure until the keycap clicks into place.
      Pergunte ao FixBot
      Comentar
    5. Epomaker Shadow-X Keycap Replacement: passo 5, imagem 1 %32 Epomaker Shadow-X Keycap Replacement: passo 5, imagem 2 %32
      • Once all keycaps are installed, reconnect the keyboard to power and test each key for proper fit and function.
      Pergunte ao FixBot
      Comentar
Conclusão
You have successfully replaced the keycaps on your Epomaker Shadow-X keyboard! The new keycaps should enhance both the aesthetic and feel of your keyboard. Test each key to ensure they are securely attached and functioning smoothly, and enjoy the refreshed look of your setup.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Ao todo: 390
