Introdução
Replacing your camera for the Enabot can be essential for your viewing experience. Your camera can severely impact your utilization of the Enabot EBO SE since you're viewing everything through the camera. Sometimes the camera can be dirty or not functioning properly leading to potential problems. In these following steps we will show you how to replace your camera.
O que você precisa
Gently turn the robot upside down.
Place the robot on a stable surface to prevent it from rolling or falling.
Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
Use the iFixit opening tool to unlock the side gray tab and free the orange & black ribbon cable.
Select one of the release tabs on the edge of the upper casing that holds the motherboard in place.
Place one finger in between the motherboard and the upper casing.
Pull the release tab back while lifting the motherboard with your other finger to "pop" the motherboard out of the casing.
Use a Phillips #00 screwdriver to remove all five 7.4 mm screws from the upper casing.
