Introdução
Replacing the battery in the Enabot EBO SE can be essential in prolonging the lifespan on this product. Overcharging or a faulty battery can drastically impact the ability of the Enabot EBO SE to function. Replacing the battery when damaged or worn down can revitalize your robot pal and help prevent unnecessary e-waste. In these following steps we will show you how to replace your battery.
O que você precisa
Gently turn the robot upside down.
Place the robot on a stable surface to prevent it from rolling or falling.
Use a Torx screwdriver to remove the four 9 mm screws from the assembly.
Use the iFixit opening tool or your fingernail to disconnect the cable by placing the edge underneath the gray tab.
Flip the tab up and pull the ribbon cable out.
Disconnect the red and blue wires from the daughterboard by using your finger nails to pull up on the connector to disconnect.
6 outras pessoas executaram este guia.
8Comentários do guia
Una guía fantástica, pero no puedo seguirla porque no encuentro el recambio de la batería ¿Se puede usar una genérica? ¿Alguna referencia que me ayude a encontrar el recambio?
tengo la misma duda, entendí perfecto el tutorial, que tipo de batería lleva?
What type of battery?
18650 battery with ph2.0/2p connector
Do you know what's the original battery capacity in mah?
