Ir para o conteúdo principal
Emson Star Wars R2-D2 Humidifier Fan Replacement
O que você precisa
    1. Emson Star Wars R2-D2 Humidifier Fan Replacement, Fan: passo 1, imagem 1 %32
      • Remove the top cover of the humidifier by pulling upwards.
      Pergunte ao FixBot
      Comentar
    2. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 2, imagem 1 %32
      • Grip the dial from the front of the device and gently pull it away to remove it.
      Pergunte ao FixBot
      Comentar
    3. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 3, imagem 1 %32
      • Remove the blue water tank of the humidifier by pulling upwards.
      Pergunte ao FixBot
      Comentar
    4. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 4, imagem 1 %32 Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 4, imagem 2 %32
      • Use a PH1 screwdriver bit and 150mm extension to unscrew the four screws from the bottom cover.
      Pergunte ao FixBot
      Comentar
    5. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 5, imagem 1 %32
      • Remove the blue plastic top by pulling upwards on the middle notch.
      Pergunte ao FixBot
      Comentar
    6. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 6, imagem 1 %32
      • This is where the fan is located. Carefully remove the fan from its compartment.
      • At this stage, you may remove the pin connector of the fan from the printed circuit board. However, it may be difficult to pull the pin. We recommend removing the printed circuit board for more clearance during removal.
      • Remove the screws on the printed circuit board using the same PH1 driver.
      Pergunte ao FixBot
      Comentar
    7. Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 7, imagem 1 %32 Emson Star Wars R2-D2 Humidifier Fan Replacement: passo 7, imagem 2 %32
      • Grip the fan's connector located on the printed circuit board and pull it away from the connector (see second picture).
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Yash Chari
Membro desde: 02/15/17
240 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 8-5, Eyestone Spring 2017 Membro de USF Tampa, Team 8-5, Eyestone Spring 2017
USFT-EYESTONE-S17S8G5
4 Membros
Autoria de 25 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 1,096
