Introdução
If your tablet will not connect to wifi, even after you have reset the router, you can use this guide to replace the wifi antenna. You should be able to easily identify which part this is, as it is a long wire attached to the motherboard. You will need tools such as a Phillips Head screwdriver with a #00 3mm screw, a spudger, plastic opening tool, as well as a soldering iron to complete the job.
O que você precisa
Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
Desolder the connections to remove the antenna.
Refer to the soldering technique guide.
