Ir para o conteúdo principal
Ematic eGlide 4 Screen Replacement
O que você precisa
  1. Ematic eGlide 4 Screen Replacement, Rear Panel: passo 1, imagem 1 %32
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Screen Replacement: passo 2, imagem 1 %32
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Screen Replacement: passo 3, imagem 1 %32 Ematic eGlide 4 Screen Replacement: passo 3, imagem 2 %32
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Screen Replacement, Side Button Array: passo 4, imagem 1 %32
    • Remove the 3 Phillips #00 4.5 mm screws from the side button array.
  5. Ematic eGlide 4 Screen Replacement: passo 5, imagem 1 %32 Ematic eGlide 4 Screen Replacement: passo 5, imagem 2 %32
    • Slide the grey ribbon wire connector clip away from the ribbon wire port on the motherboard using the pointed tip of a spudger. This process will unclip the wire from the motherboard to release connection.
    • You do not need to fully disconnect the ribbon wire clip from the ribbon wire port: the clip will stay attached in a loose fit.
    • Remove the ribbon wire from the ribbon wire port on the motherboard.
  6. Ematic eGlide 4 Screen Replacement: passo 6, imagem 1 %32
    • Remove the side button array from the device.
  7. Ematic eGlide 4 Screen Replacement, Motherboard: passo 7, imagem 1 %32
    • Remove the gold ribbon wire from the ribbon wire port on the motherboard.
  8. Ematic eGlide 4 Screen Replacement: passo 8, imagem 1 %32
    • Slide the grey ribbon wire connector clip away from the white ribbon wire port on the screen board using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port on the screen board.
  9. Ematic eGlide 4 Screen Replacement: passo 9, imagem 1 %32
    • Slide the grey ribbon wire connector clip away from the ribbon wire port using the pointed tip of a spudger.
    • Remove the ribbon wire from the ribbon wire port.
    • If you have already removed the side button array you do not need to do this step.
  10. Ematic eGlide 4 Screen Replacement: passo 10, imagem 1 %32
    • Remove the 2 Phillips #00 4.5 mm screws from the motherboard.
  11. Ematic eGlide 4 Screen Replacement: passo 11, imagem 1 %32
    • Desolder the Wi-Fi Adaptor
    • If not replacing the motherboard or Wi-Fi Adaptor, omit this step
    • See ifixit's guide to soldering and desoldering for help: How to Solder and Desolder Connections
  12. Ematic eGlide 4 Screen Replacement: passo 12, imagem 1 %32
    • Desolder the battery connections
    • If not replacing the motherboard or battery, omit this step
  13. Ematic eGlide 4 Screen Replacement: passo 13, imagem 1 %32 Ematic eGlide 4 Screen Replacement: passo 13, imagem 2 %32
    • Slide and pull the motherboard out of its current position, so that the ports disconnect from the device.
    • Lift the motherboard out of the device.
  14. Ematic eGlide 4 Screen Replacement, Screen: passo 14, imagem 1 %32
    • Gently pull the front case clips down and off of the back of the screen
  15. Ematic eGlide 4 Screen Replacement: passo 15, imagem 1 %32
    • Gently pull the front case clips down and off of the back of the screen for all of the remaining clips
  16. Ematic eGlide 4 Screen Replacement: passo 16, imagem 1 %32 Ematic eGlide 4 Screen Replacement: passo 16, imagem 2 %32
    • Gently pull the screen away from the front case
Conclusão
Bailey Hughes
Membro desde: 03/22/15
617 Reputação
Autoria de 6 guias
Equipe
Baylor, Team 5-8, Williams Spring 2015 Membro de Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 297
