Introdução
This guide covers the steps necessary in order to safely remove the speaker from the table for replacement.
O que você precisa
Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
1Comentário do guia
This help us alot, thanks for posting troubleshooting
