Ir para o conteúdo principal
Ematic Genesis Camera Replacement
O que você precisa
  1. Ematic Genesis Camera Replacement, Ematic Genesis Casing: passo 1, imagem 1 %32 Ematic Genesis Camera Replacement, Ematic Genesis Casing: passo 1, imagem 2 %32 Ematic Genesis Camera Replacement, Ematic Genesis Casing: passo 1, imagem 3 %32
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
    Pergunte ao FixBot
    Comentar
  2. Ematic Genesis Camera Replacement: passo 2, imagem 1 %32 Ematic Genesis Camera Replacement: passo 2, imagem 2 %32 Ematic Genesis Camera Replacement: passo 2, imagem 3 %32
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
    Pergunte ao FixBot
    Comentar
  3. Ematic Genesis Camera Replacement: passo 3, imagem 1 %32
    • Remove back plate from screen plate and lay both down flat next to each other.
    Pergunte ao FixBot
    Comentar
  4. Ematic Genesis Camera Replacement, Camera: passo 4, imagem 1 %32 Ematic Genesis Camera Replacement, Camera: passo 4, imagem 2 %32
    • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
    Pergunte ao FixBot
    Comentar
  5. Ematic Genesis Camera Replacement: passo 5, imagem 1 %32 Ematic Genesis Camera Replacement: passo 5, imagem 2 %32
    • Lift up the black lever of the connector that holds the camera ribbon in place.
    Pergunte ao FixBot
    Comentar
  6. Ematic Genesis Camera Replacement: passo 6, imagem 1 %32 Ematic Genesis Camera Replacement: passo 6, imagem 2 %32
    • Gently pull the ribbon out of the connector and lift the camera out of the casing.
    • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Baylor, Team 4-3, Williams Spring 2015 Membro de Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 43
Ao todo: 438
