Introdução
This guide will demonstrate the necessary steps in order to safely remove the camera from the Ematic Genesis Tablet.
O que você precisa
Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
