Ir para o conteúdo principal
Ematic FunTab 3 Motherboard Replacement
O que você precisa
  1. Ematic FunTab 3 Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement, Back Panel: passo 1, imagem 2 %32 Ematic FunTab 3 Motherboard Replacement, Back Panel: passo 1, imagem 3 %32
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Motherboard Replacement: passo 2, imagem 1 %32
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Motherboard Replacement, Battery: passo 3, imagem 1 %32
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Motherboard Replacement: passo 4, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 4, imagem 2 %32 Ematic FunTab 3 Motherboard Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
  5. Ematic FunTab 3 Motherboard Replacement: passo 5, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 5, imagem 2 %32 Ematic FunTab 3 Motherboard Replacement: passo 5, imagem 3 %32
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
  6. Ematic FunTab 3 Motherboard Replacement: passo 6, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 6, imagem 2 %32
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
  7. Ematic FunTab 3 Motherboard Replacement, Speaker: passo 7, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement, Speaker: passo 7, imagem 2 %32
  8. Ematic FunTab 3 Motherboard Replacement: passo 8, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 8, imagem 2 %32 Ematic FunTab 3 Motherboard Replacement: passo 8, imagem 3 %32
    • After the connections are desoldered, remove the speaker by prying it up using a plastic opening tool.
    • There is glue on the back of the speaker. Some more force may be required.
  9. Ematic FunTab 3 Motherboard Replacement, Camera: passo 9, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement, Camera: passo 9, imagem 2 %32
  10. Ematic FunTab 3 Motherboard Replacement: passo 10, imagem 1 %32
    • Use the plastic opening tool to flip up the black retaining tab.
  11. Ematic FunTab 3 Motherboard Replacement: passo 11, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 11, imagem 2 %32
    • Pull out the wire ribbon connected to the camera.
    • The camera is held in place by glue, so extra force may be required.
    • Remove the camera from the device.
  12. Ematic FunTab 3 Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Remove the black tape to reveal the screen connector.
  13. Ematic FunTab 3 Motherboard Replacement: passo 13, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 13, imagem 2 %32
    • Flip up the retaining tab using the plastic opening tool.
    • Pull out the screen wire ribbon to disconnect the screen and motherboard.
  14. Ematic FunTab 3 Motherboard Replacement: passo 14, imagem 1 %32 Ematic FunTab 3 Motherboard Replacement: passo 14, imagem 2 %32
    • Using a PH 00 screwdriver, remove the four 4.5 mm screws that are holding the motherboard in place.
  15. Ematic FunTab 3 Motherboard Replacement: passo 15, imagem 1 %32
    • It is now safe to remove and replace the old motherboard with your new motherboard.
Conclusão
Amanda Davis
Membro desde: 07/11/18
581 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 444
