Ir para o conteúdo principal
Ematic FunTab 3 Battery Replacement
O que você precisa
  1. Ematic FunTab 3 Battery Replacement, Back Panel: passo 1, imagem 1 %32 Ematic FunTab 3 Battery Replacement, Back Panel: passo 1, imagem 2 %32 Ematic FunTab 3 Battery Replacement, Back Panel: passo 1, imagem 3 %32
    • Turn off the device before starting
    • To prevent damage, open the device on the side without the buttons.
    • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
    • Slide the plastic opening tool down the long side of the device.
    • Insert tool again and slide it down the long slide of the case a second time.
  2. Ematic FunTab 3 Battery Replacement: passo 2, imagem 1 %32
    • Pull the back panel away from the screen.
  3. Ematic FunTab 3 Battery Replacement, Battery: passo 3, imagem 1 %32
    • Remove the black tape to reveal the wire ribbon connector.
  4. Ematic FunTab 3 Battery Replacement: passo 4, imagem 1 %32 Ematic FunTab 3 Battery Replacement: passo 4, imagem 2 %32 Ematic FunTab 3 Battery Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Flip up the black retaining tab using the plastic opening tool.
    • Pull out the large wire ribbon that crosses over the battery.
    • You may need tweezers to pull out the wire ribbon.
  5. Ematic FunTab 3 Battery Replacement: passo 5, imagem 1 %32 Ematic FunTab 3 Battery Replacement: passo 5, imagem 2 %32 Ematic FunTab 3 Battery Replacement: passo 5, imagem 3 %32
    • Insert the plastic opening tool under the battery.
    • Using the plastic opening tool, pry up the battery.
    • There is tape on the back of the battery. Some more force may be required to separate the battery from the back of the display.
  6. Ematic FunTab 3 Battery Replacement: passo 6, imagem 1 %32 Ematic FunTab 3 Battery Replacement: passo 6, imagem 2 %32
    • Remove the wires from the motherboard using a soldering iron tool. Here is a link on How To Solder and Desolder Connections.
    • After the connections are desoldered, remove the battery.
    • Close the black ribbon retaining tabs once ribbons are inserted during reassembly.
Conclusão
Amanda Davis
Membro desde: 07/11/18
581 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 779
