Ir para o conteúdo principal
Ematic FunTab 3 Back Panel Replacement
O que você precisa
    1. Ematic FunTab 3 Back Panel  Replacement, Back Panel: passo 1, imagem 1 %32 Ematic FunTab 3 Back Panel  Replacement, Back Panel: passo 1, imagem 2 %32 Ematic FunTab 3 Back Panel  Replacement, Back Panel: passo 1, imagem 3 %32
      • Turn off the device before starting
      • To prevent damage, open the device on the side without the buttons.
      • Insert the hooked end of the plastic opening tool in the gap between the screen and the back panel on the edge of the device.
      • Slide the plastic opening tool down the long side of the device.
      • Insert tool again and slide it down the long slide of the case a second time.
      Pergunte ao FixBot
      Comentar
    2. Ematic FunTab 3 Back Panel  Replacement: passo 2, imagem 1 %32
      • Pull the back panel away from the screen.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
UW Tacoma, Team S1-G5, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G5, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G5
4 Membros
Autoria de 12 guias
1Comentário do guia
Our funtab3 is not work because we want to work but Anything is not work. We see a tiny crack
Adelaida Lopez Arias - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 25
Ao todo: 433
