Introdução
This guide will help you replace the internal speakers for your Ematic eGlide 4 and where to locate the speaker connection. The speakers are connected to the rear panel using a mild adhesive that does not need special care. The speakers are also connected to the motherboard via soldered wire connections, which must be desoldered in order to replace the speakers.
O que você precisa
Quase terminado!
Conclusão
