Ir para o conteúdo principal
Ematic EGQ307 Battery Replacement
O que você precisa
  1. Ematic EGQ307 Battery Replacement, Battery: passo 1, imagem 1 %32 Ematic EGQ307 Battery Replacement, Battery: passo 1, imagem 2 %32
    • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
  2. Ematic EGQ307 Battery Replacement: passo 2, imagem 1 %32 Ematic EGQ307 Battery Replacement: passo 2, imagem 2 %32
    • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
    • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
  3. Ematic EGQ307 Battery Replacement: passo 3, imagem 1 %32
    • 3. Once you pry off the plastic backing, you will expose the battery.
  4. Ematic EGQ307 Battery Replacement: passo 4, imagem 1 %32 Ematic EGQ307 Battery Replacement: passo 4, imagem 2 %32 Ematic EGQ307 Battery Replacement: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Plastic Cards
    $2.99
    Comprar
    • 4. Remove the tape holding the battery to the plastic frame. The battery is glued to the back of the LED. Pry the battery off the LED using a plastic card.
    • Do not bend or warp the battery. Even though the battery may not be working, it is still dangerous.
  5. Ematic EGQ307 Battery Replacement: passo 5, imagem 1 %32
    • If replacing the battery, unplug the black and red wires gently from the hardware and take off the battery .
    • If not replacing it, do not disconnect the red and black wires.
    • If replacing the battery, you will need a soldering kit to reconnect the wires with the new battery after disconnecting the old battery.
    • How To Solder and Desolder Connections.
Conclusão
To reassemble your device, follow these instructions in reverse order. Note, you need to solder the battery wires onto the motherboard.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 17
Duração total: 5,096
