Ir para o conteúdo principal
Element GC-1020 Battery Replacement
O que você precisa
  1. Element GC-1020 Battery  Replacement, Back Cover Replacement Guide: passo 1, imagem 1 %32
    • Unscrew the four screws (size: 3.175mm) on the left and right side of the Element Electronics GC-1020 device using the PH#0 screwdriver.
  2. Element GC-1020 Battery  Replacement: passo 2, imagem 1 %32
    • Carefully pull the back of the device (the silver portion) apart from the rest of the device.
    • If you pull back too forcefully the power button would move out of place.
  3. Element GC-1020 Battery  Replacement, Battery: passo 3, imagem 1 %32 Element GC-1020 Battery  Replacement, Battery: passo 3, imagem 2 %32
    • Then remove the battery from the device through soldering the black and red wires connected to the motherboard.
    • This replacement will require a soldering station.
    • To find out more on soldering refer to the Soldering and Desolder page to help you through this process.
Conclusão
Lashaun Noel
Membro desde: 09/25/15
591 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 334
