Ir para o conteúdo principal
Electrohome EAAC475 Display Replacement
O que você precisa
  1. Electrohome EAAC475 Display Replacement, Battery: passo 1, imagem 1 %32 Electrohome EAAC475 Display Replacement, Battery: passo 1, imagem 2 %32
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
    Pergunte ao FixBot
    Comentar
  2. Electrohome EAAC475 Display Replacement: passo 2, imagem 1 %32
    • Remove the flat lithium battery.
    Pergunte ao FixBot
    Comentar
  3. Electrohome EAAC475 Display Replacement, Buttons: passo 3, imagem 1 %32 Electrohome EAAC475 Display Replacement, Buttons: passo 3, imagem 2 %32
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
    Pergunte ao FixBot
    Comentar
  4. Electrohome EAAC475 Display Replacement: passo 4, imagem 1 %32 Electrohome EAAC475 Display Replacement: passo 4, imagem 2 %32 Electrohome EAAC475 Display Replacement: passo 4, imagem 3 %32
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
    Pergunte ao FixBot
    Comentar
  5. Electrohome EAAC475 Display Replacement: passo 5, imagem 1 %32 Electrohome EAAC475 Display Replacement: passo 5, imagem 2 %32
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
    Pergunte ao FixBot
    Comentar
  6. Electrohome EAAC475 Display Replacement, Display: passo 6, imagem 1 %32 Electrohome EAAC475 Display Replacement, Display: passo 6, imagem 2 %32
    • Remove the two 8 mm Phillips screws supporting the circuit board.
    • Pull off the circuit board to access the panels below.
    Pergunte ao FixBot
    Comentar
  7. Electrohome EAAC475 Display Replacement: passo 7, imagem 1 %32 Electrohome EAAC475 Display Replacement: passo 7, imagem 2 %32
    • Remove the two 6 mm Phillips screws supporting the mini circuit board for the frontal buttons.
    • Remove the mini circuit board.
    Pergunte ao FixBot
    Comentar
  8. Electrohome EAAC475 Display Replacement: passo 8, imagem 1 %32 Electrohome EAAC475 Display Replacement: passo 8, imagem 2 %32
    • Move the now free circuit boards away from the display.
    • Remove the final two 7 mm Phillips screws securing the display.
    • Pull the display screen away from the casing.
    Pergunte ao FixBot
    Comentar
  9. Electrohome EAAC475 Display Replacement: passo 9, imagem 1 %32
    • You have successfully accessed the display.
    • Replacing the display with a new one will be challenging as soldering and connecting micro wires are necessary.
    Pergunte ao FixBot
    Comentar
Conclusão
Sohail Khatri
Membro desde: 02/16/16
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-1, Harley Spring 2016 Membro de IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 57
Ao todo: 1,295
