Ir para o conteúdo principal
Electro-Harmonix Bass Mono Synth Wiring Repair
O que você precisa
  1. Electro-Harmonix Bass Mono Synth Wiring Repair, Electro-Harmonix Bass Mono Synth Wiring Repair: passo 1, imagem 1 %32 Electro-Harmonix Bass Mono Synth Wiring Repair, Electro-Harmonix Bass Mono Synth Wiring Repair: passo 1, imagem 2 %32
    • Gently pry the five knobs with an opening tool until they are loose.
    • Once the knobs are loose, gently pull them off.
    • Be careful not to scratch or damage the pedal's paint.
  2. Electro-Harmonix Bass Mono Synth Wiring Repair: passo 2, imagem 1 %32 Electro-Harmonix Bass Mono Synth Wiring Repair: passo 2, imagem 2 %32
    • Using the adjustable wrench, loosen the hex nuts by turning them counterclockwise.
    • Once the hex nuts are loose, remove them and their washers by hand.
    • Remember to keep each size of hex nut and washer separate for easy reassembly.
  3. Electro-Harmonix Bass Mono Synth Wiring Repair: passo 3, imagem 1 %32 Electro-Harmonix Bass Mono Synth Wiring Repair: passo 3, imagem 2 %32
    • Using the adjustable wrench, remove the hex nuts from the stomp buttons.
    • The stomp buttons will become loose as the hex nuts are removed.
  4. Electro-Harmonix Bass Mono Synth Wiring Repair: passo 4, imagem 1 %32 Electro-Harmonix Bass Mono Synth Wiring Repair: passo 4, imagem 2 %32 Electro-Harmonix Bass Mono Synth Wiring Repair: passo 4, imagem 3 %32
    • Using the adjustable wrench, remove the hex nuts and their washers from the left and right sides of the pedal.
  5. Electro-Harmonix Bass Mono Synth Wiring Repair: passo 5, imagem 1 %32 Electro-Harmonix Bass Mono Synth Wiring Repair: passo 5, imagem 2 %32 Electro-Harmonix Bass Mono Synth Wiring Repair: passo 5, imagem 3 %32
    • Use a Phillips #1 screwdriver to remove all four screws from the back of the device.
    • Remove the back plate from the pedal.
  6. Electro-Harmonix Bass Mono Synth Wiring Repair: passo 6, imagem 1 %32 Electro-Harmonix Bass Mono Synth Wiring Repair: passo 6, imagem 2 %32 Electro-Harmonix Bass Mono Synth Wiring Repair: passo 6, imagem 3 %32
    • The motherboard will be loose at this step except for the 9V power port which is snug in the case.
    • Using an opening tool, push or pry the 9V power port free of the case.
    • Gently remove the motherboard.
    • The stomp buttons will be loose at this step, so remember where they came from.
  7. Electro-Harmonix Bass Mono Synth Wiring Repair: passo 7, imagem 1 %32
    • Put on personal protective equipment. This includes safety goggles, gloves, and closed toed shoes.
    • Using the soldering tool, solder the damaged connections of the I/O jacks on the bottom of the motherboard.
    • If you have no experience with soldering, follow this guide.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 376
