Ir para o conteúdo principal
Electric Eel Drain Cleaner Cable Replacement
O que você precisa
  1. Electric Eel Drain Cleaner Cable Replacement, Remove the Guide Spring: passo 1, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement, Remove the Guide Spring: passo 1, imagem 2 %32 Electric Eel Drain Cleaner Cable Replacement, Remove the Guide Spring: passo 1, imagem 3 %32
    • Unplug your drain cleaner before starting this guide. Because this device may have been used in a septic setting, it should be cleaned and disinfected as much as possible before disassembly.
    • Wear gloves to protect your hands from injury when handling the cable.
    • Ensure the cable is completely retracted into the auto-feeder.
    • Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
    • Remove the guide spring.
  2. Electric Eel Drain Cleaner Cable Replacement, Release the Tension Spring: passo 2, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement, Release the Tension Spring: passo 2, imagem 2 %32 Electric Eel Drain Cleaner Cable Replacement, Release the Tension Spring: passo 2, imagem 3 %32
    • Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
  3. Electric Eel Drain Cleaner Cable Replacement, Set the Feeder in Neutral Position: passo 3, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement, Set the Feeder in Neutral Position: passo 3, imagem 2 %32 Electric Eel Drain Cleaner Cable Replacement, Set the Feeder in Neutral Position: passo 3, imagem 3 %32
    • Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
  4. Electric Eel Drain Cleaner Cable Replacement, Disengage the Top Bearing: passo 4, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement, Disengage the Top Bearing: passo 4, imagem 2 %32
    • Push the top control finger up as far as possible.
    • This disengages the top feeder assembly and allows the cable to freely move through the feeder. The finger may fall back down on its own and restrict cable movement. If this occurs, simply push the finger back up.
  5. Electric Eel Drain Cleaner Cable Replacement, Uncoil the Cable: passo 5, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement, Uncoil the Cable: passo 5, imagem 2 %32
    • Grab the end of the cable and pull to begin removing the cable from the drum.
    • If the the cable won't pass through the feeder, ensure that the top bearing is completely disengaged as described in step 4 of this guide.
  6. Electric Eel Drain Cleaner Cable Replacement: passo 6, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement: passo 6, imagem 2 %32
    • Continue pulling out the cable until it reaches the end. The very end of the cable and the cable anchor will still be attached to the back side of the drum.
  7. Electric Eel Drain Cleaner Cable Replacement, Remove the Cable Anchor: passo 7, imagem 1 %32
    • Use a flat-head screwdriver to remove the screw on the rear face of the drum that secures the cable anchor.
    • You may need to rotate the drum so that the screw is accessible from bottom rear of the drain cleaner.
    • During reassembly, twist the cable so that the threaded hole in the cable anchor is facing the back side of the drum.
  8. Electric Eel Drain Cleaner Cable Replacement: passo 8, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement: passo 8, imagem 2 %32 Electric Eel Drain Cleaner Cable Replacement: passo 8, imagem 3 %32
    • Pull the end of the cable out of the side of the drum to access the cable anchor.
  9. Electric Eel Drain Cleaner Cable Replacement: passo 9, imagem 1 %32
    • Use a 1/8" hex key to remove the grub screw from the cable anchor.
  10. Electric Eel Drain Cleaner Cable Replacement: passo 10, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement: passo 10, imagem 2 %32
    • Remove the cable anchor from the cable.
  11. Electric Eel Drain Cleaner Cable Replacement, Remove the Cable: passo 11, imagem 1 %32 Electric Eel Drain Cleaner Cable Replacement, Remove the Cable: passo 11, imagem 2 %32 Electric Eel Drain Cleaner Cable Replacement, Remove the Cable: passo 11, imagem 3 %32
    • Pull the rest of the cable out of the drum through the auto-feeder to remove it.
Conclusão
Tarun Thiruma
Membro desde: 11/20/19
35.516 Reputação
Autoria de 134 guias
2 comentários
make sure to feed back in counter clockwise
MIGUEL - Responder
there is a ANCHOR CABLE, P/N: 1/2M3, that can be left on the drum and the new cable can be attached to it. Much easier to change the cable when yo don't have to re-attach it each time, to the drum.
MICHEL - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 34
Últimos 30 dias: 121
Duração total: 4,874
