Ir para o conteúdo principal
Eightarc Fusion Button Replacement
O que você precisa
  1. Eightarc Fusion Button Replacement, Buttons: passo 1, imagem 1 %32
    • Because of the protruding joystick on the top of the controller, make sure to work on a soft surface, or prop the controller up to avoid stress on the joystick.
    • Place the controller face down (buttons and joystick down).
    • Use a Phillips Head #1 screwdriver to remove the eight 9.65 mm screws located on the felt and metal backplate.
    • Do not confuse the four screws in the rubber feet with the eight screws in the felt. The screws in the feet do not need to be removed.
    Pergunte ao FixBot
    Comentar
  2. Eightarc Fusion Button Replacement: passo 2, imagem 1 %32
    • Open the door for the cord storage compartment on the right side of the device.
    • Reach under the panel and push upwards on the back panel. Lift it up and remove it from the device.
    Pergunte ao FixBot
    Comentar
  3. Eightarc Fusion Button Replacement: passo 3, imagem 1 %32
    • Remove the clear rubber casing around the wire connector by lifting the casing up and moving it up along the wire.
    • Repeat for second clear rubber casing.
    Pergunte ao FixBot
    Comentar
  4. Eightarc Fusion Button Replacement: passo 4, imagem 1 %32 Eightarc Fusion Button Replacement: passo 4, imagem 2 %32
    • Gently grasp and lift up on the metal section of the wire to remove the wire from the button connector.
    • A slight wiggling motion might help remove the wire from the connector.
    • Make sure to keep track of which wires go to what button slot location.
    Pergunte ao FixBot
    Comentar
  5. Eightarc Fusion Button Replacement: passo 5, imagem 1 %32 Eightarc Fusion Button Replacement: passo 5, imagem 2 %32
    • Gently depress the two plastic tabs on both of the sides of the button casing.
    • The plastic tabs on the buttons are extremely fragile, handle with care.
    • Slightly push the button down, out of the controller until it slides out.
    • During re-assembly, make sure the button tabs align with the slots in the casing when inserting the button back in.
    Pergunte ao FixBot
    Comentar
Conclusão
Austin
Membro desde: 01/28/15
245 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 17-35, Amido Winter 2015 Membro de Cal Poly, Team 17-35, Amido Winter 2015
CPSU-AMIDO-W15S17G35
4 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 27
Ao todo: 1,143
