Ir para o conteúdo principal
Eclipse 180BL Battery Replacement
O que você precisa
  1. Eclipse 180BL Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove the two screws located on the bottom of the device with a phillips head screw driver.
    • The two screws can be removed using the PH00 head from the iFixit repair toolkit.
    • Both screws are 1/8 inch in length.
    • The bottom cap will come off to reveal the inside main component.
    Pergunte ao FixBot
    Comentar
  2. Eclipse 180BL Battery Replacement: passo 2, imagem 1 %32 Eclipse 180BL Battery Replacement: passo 2, imagem 2 %32
    • Remove the main inner component using Spudger, by pushing on the USB port. This will take some force.
    • Hold on the sides with your fingers, and push to release from the top.
    Pergunte ao FixBot
    Comentar
  3. Eclipse 180BL Battery Replacement: passo 3, imagem 1 %32 Eclipse 180BL Battery Replacement: passo 3, imagem 2 %32 Eclipse 180BL Battery Replacement: passo 3, imagem 3 %32
    • The plastic LCD cover and the key pad will now be loose; they were held in place by the tension between the case and the internal main component.
    • Locate the large square pack with a black and red wire coming out of it, this is the battery.
    • Cut the red and black wires to remove the old battery.
    Pergunte ao FixBot
    Comentar
  4. Eclipse 180BL Battery Replacement: passo 4, imagem 1 %32
    • To Replace, connect the two new lines ( red and black) between the new battery and the device.
    • You have successfully replaced the battery!
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 66
Ao todo: 2,199
