Ir para o conteúdo principal
EBK340 Powerhead Replacement
O que você precisa
  1. EBK340  Powerhead  Replacement, Remove Outer Cover: passo 1, imagem 1 %32
    • Position the device so brushes are upwards and visible
    • Unscrew the 6 outer screws. 2 on the edge of the brush crevice, and 4 nearer to the wheels.
    • Turn over the device.
    • Pull the cover off gently.
    Pergunte ao FixBot
    Comentar
  2. EBK340  Powerhead  Replacement, Remove Inner Cover: passo 2, imagem 1 %32
    • Unscrew the 2 screws indicated, one visible, the other within a deep hole
    • Gently pull off the cover. Careful not to torque the plastic teeth shown in orange.
    Pergunte ao FixBot
    Comentar
  3. EBK340  Powerhead  Replacement, Replace Neck Joint: passo 3, imagem 1 %32 EBK340  Powerhead  Replacement, Replace Neck Joint: passo 3, imagem 2 %32
    • Gently lift the two LED lights upwards and away for the moment.
    • Gently lift out the defective neck joint.
    • Slide in the replacement joint.
    • Replace the lights into the molded corners that hold their board.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
FolsomMaids Office
Membro desde: 10/09/19
167 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 7
Últimos 30 dias: 18
Ao todo: 288
