Ir para o conteúdo principal
Dyson v6 Absolute Battery Pack Replacement
O que você precisa
    1. Dyson v6 Absolute Battery Pack Replacement, Bin: passo 1, imagem 1 %32
      • Unplug the device.
      Pergunte ao FixBot
      Comentar
    2. Dyson v6 Absolute Battery Pack Replacement: passo 2, imagem 1 %32
      • Push down the red lever located on the outside of the bin, next to the device handle, to open the door to the debris bin.
      • Avoid pressing the trigger on the handle opposite the red lever, which activates the motor.
      Pergunte ao FixBot
      Comentar
    3. Dyson v6 Absolute Battery Pack Replacement: passo 3, imagem 1 %32
      • Push the red lever down a second time to release the debris bin.
      Pergunte ao FixBot
      Comentar
    4. Dyson v6 Absolute Battery Pack Replacement: passo 4, imagem 1 %32
      • Pull bin away from the cyclone.
      Pergunte ao FixBot
      Comentar
    1. Dyson v6 Absolute Battery Pack Replacement, Battery Pack: passo 5, imagem 1 %32
      • Locate the screw on the battery pack.
      • Use a Phillips #2 screwdriver to unscrew the battery pack.
      Pergunte ao FixBot
      Comentar
    2. Dyson v6 Absolute Battery Pack Replacement: passo 6, imagem 1 %32
      • Locate the screw on the device handle.
      • Use a Phillips #2 screwdriver to remove the screw and release the battery pack.
      Pergunte ao FixBot
      Comentar
    3. Dyson v6 Absolute Battery Pack Replacement: passo 7, imagem 1 %32 Dyson v6 Absolute Battery Pack Replacement: passo 7, imagem 2 %32
      • Pull the battery pack down and away from the device.
      Pergunte ao FixBot
      Comentar
Conclusão
143 outras pessoas executaram este guia.
30Comentários do guia
very good article 10 out of 10
karl thiele - Responder Compartilhar
Nice article. Not too long or too short. Perfect pictures, too.
timlevin - Responder Compartilhar
Great pictures, very straight forward, and I really appreciate you guys taking the time to put this together. I managed to “kill” my Dyson by getting a little over-zealous with the cleaning. I’m going to take it apart, let it dry completely, and hope that a new battery is the only issue. Anyway, your presentation has given me the courage to go forward - may not work, but…..
Meg Olhasque - Responder Compartilhar
Hi, I bought my Dyson v6 for Christmas 2016. My battery only last few seconds at dis stage. It seems a short time for battery needing replacing. Is this normal .
Ellymck - Responder Compartilhar
I had the same problem with my dyson v6 slim. The battery didn't last long on mine either! I was very disappointed especially when you pay $500 for one of these.
Beverley Mingo - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 15
Últimos 7 dias: 143
Últimos 30 dias: 654
Ao todo: 310,153
