Ir para o conteúdo principal
Dyson V8 Animal Intake Filter Replacement
O que você precisa
    1. Dyson V8 Animal Intake Filter Replacement, Intake Filter: passo 1, imagem 1 %32 Dyson V8 Animal Intake Filter Replacement, Intake Filter: passo 1, imagem 2 %32 Dyson V8 Animal Intake Filter Replacement, Intake Filter: passo 1, imagem 3 %32
      • Twist the air intake filter cap counter clock wise.
      • Pull the air intake filter cap away from the handle.
      Pergunte ao FixBot
      Comentar
Conclusão
Equipe
Cal Poly, Team S19-G1, White Winter 2020 Membro de Cal Poly, Team S19-G1, White Winter 2020
CPSU-WHITE-W20S19G1
4 Membros
Autoria de 23 guias
1Comentário do guia
Its the post motor exhaust. It’s not an intake. I am only being pedantic because I have spent ages trying to work out the whistling sound and it;s because on max it pushes the HEPA filter on this part out too hard on the catches and the rubber seal does not stay tight.
Jez D - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 77
Ao todo: 5,764
