Introdução
The bin holds the debris that the vacuum collects. If your Dyson V8 Animal’s bin is clogged or full, use this guide to clear the debris. A clogged or full bin will cause the vacuum to be ineffective at picking up debris and may cause the vacuum to not power on.
Before using this guide, visually inspect the bin to see if it is clogged or full. If the bin is not clogged or full and your vacuum is still experiencing problems refer to this Dyson V8 Troubleshooting guide.
No special skills are required for this guide.
Before beginning, make sure to turn off the vacuum and disconnect it from any external power source.
O que você precisa
Uma outra pessoa concluiu este guia.
