Introdução
Require battery removal, which is not included due to device not having a battery. Connection tubing will need to be removed before motor replacement.
O que você precisa
Identify the two white components between the vacuum handle and the attached component.
10 outras pessoas executaram este guia.
3Comentários do guia
really good can understand and not too technical
I am terrible at fixing things and this helped me put my vacuum back together after it fell and the motor detached from the handle. Thank you!!!
Can't see the tweezer being inserted into the white tabs. Picture not clear. Could not dislodge motorhead from cannister bin. Show a clearer picture. Thanks
