Ir para o conteúdo principal
Dyson Supersonic HD01 Buttons Replacement
O que você precisa
  1. Dyson Supersonic HD01 Buttons Replacement, Buttons: passo 1, imagem 1 %32 Dyson Supersonic HD01 Buttons Replacement, Buttons: passo 1, imagem 2 %32
    • Heat the iOpener in the microwave for 30 seconds and apply it immediately to the top of the buttons.
    • Leave the iOpener in place for a couple minutes.
    Pergunte ao FixBot
    Comentar
  2. Dyson Supersonic HD01 Buttons Replacement: passo 2, imagem 1 %32 Dyson Supersonic HD01 Buttons Replacement: passo 2, imagem 2 %32 Dyson Supersonic HD01 Buttons Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Microfiber Cleaning Cloths
    $3.99
    • Remove the buttons with tweezers.
    • Power button
    • Cold shot button
    • Use a microfiber towel soaked in rubbing alcohol to clean the button holes. Doing this will loosen the buttons if jammed.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
2Comentários do guia
My Dyson Supersonic will start but nor heat up. Called the company but guarantee expired by 3 months. They won't fix it.
Is there a chance to check inside and try to repair? Thanks.
mario enrico rosati - Responder Compartilhar
as far as I know only counterfit supersonics fail in that way. I had one of those. The inrush current limiter basically exploded. (because the part is sized way too small for the current in a hair dryer). Real dysons usually stop working alltogether because the thermal fuse blew.
karatektus - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 46
Últimos 30 dias: 233
Ao todo: 9,826
