Ir para o conteúdo principal
Dyson DC58 Main Body Replacement
O que você precisa
Vídeo de Apresentação
  1. Dyson DC58 Main Body Replacement, Bin: passo 1, imagem 1 %32
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
    Pergunte ao FixBot
    Comentar
  2. Dyson DC58 Main Body Replacement: passo 2, imagem 1 %32
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
    Pergunte ao FixBot
    Comentar
  3. Dyson DC58 Main Body Replacement: passo 3, imagem 1 %32
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
    Pergunte ao FixBot
    Comentar
  4. Dyson DC58 Main Body Replacement: passo 4, imagem 1 %32 Dyson DC58 Main Body Replacement: passo 4, imagem 2 %32
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
    Pergunte ao FixBot
    Comentar
  5. Dyson DC58 Main Body Replacement, Main Body: passo 5, imagem 1 %32
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
    Pergunte ao FixBot
    Comentar
  6. Dyson DC58 Main Body Replacement: passo 6, imagem 1 %32 Dyson DC58 Main Body Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
    Pergunte ao FixBot
    Comentar
  7. Dyson DC58 Main Body Replacement: passo 7, imagem 1 %32
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
    Pergunte ao FixBot
    Comentar
Conclusão
12 outras pessoas executaram este guia.
Krista St Onge
Membro desde: 09/17/15
2.260 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Membros
Autoria de 24 guias
4Comentários do guia
Mine ended up dismantled after it had been dropped. Couldn't get it back together until I read the bit about the tweezers /(pliers) and the white clips. It does not push in with out squeezing them first
Jason - Responder Compartilhar
Has anyone replaced the red release catch?
chrisashton1 - Responder Compartilhar
The white C-ring with clips must be pushed down in order to reassemble device. Takes some time to practice.
Anton Simonov - Responder Compartilhar
I'm trying to figure out how to put spring and plastic pieces back in on the inside of red lever on motor body?? Any help I'd really appreciate ?
t_picano - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 62
Ao todo: 14,625
