Ir para o conteúdo principal
Dyson DC58 Cyclone Replacement
O que você precisa
  1. Dyson DC58 Cyclone Replacement, Bin: passo 1, imagem 1 %32
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
    Pergunte ao FixBot
    Comentar
  2. Dyson DC58 Cyclone Replacement: passo 2, imagem 1 %32
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
    Pergunte ao FixBot
    Comentar
  3. Dyson DC58 Cyclone Replacement: passo 3, imagem 1 %32
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
    Pergunte ao FixBot
    Comentar
  4. Dyson DC58 Cyclone Replacement: passo 4, imagem 1 %32 Dyson DC58 Cyclone Replacement: passo 4, imagem 2 %32
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
    Pergunte ao FixBot
    Comentar
  5. Dyson DC58 Cyclone Replacement, Main Body: passo 5, imagem 1 %32
    • Flip the vacuum over so that the silver cyclone part of the vacuum is now at the base.
    Pergunte ao FixBot
    Comentar
  6. Dyson DC58 Cyclone Replacement: passo 6, imagem 1 %32 Dyson DC58 Cyclone Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the two visible white clips seen between the main body and the purple cyclone of the vacuum.
    • Use tweezers to pinch the two visible white clips together.
    • It may require a few tries to pinch the clips since the space between the main body and cyclone is small.
    Pergunte ao FixBot
    Comentar
  7. Dyson DC58 Cyclone Replacement: passo 7, imagem 1 %32
    • Tilt and pull the main body away from the purple cyclone of the vacuum.
    • You may hear a loud snap when the cyclone is released from the main body, this is to be expected.
    Pergunte ao FixBot
    Comentar
  8. Dyson DC58 Cyclone Replacement, Cyclone: passo 8, imagem 1 %32 Dyson DC58 Cyclone Replacement, Cyclone: passo 8, imagem 2 %32
    • Use the metal spudger placed between the black rim and the purple rim to separate the purple screen cover from the cyclone body.
    • Pry all the way around the screen cover.
    Pergunte ao FixBot
    Comentar
  9. Dyson DC58 Cyclone Replacement: passo 9, imagem 1 %32
    • Use a T9 screw driver to remove the five 14mm screws around the edge of the cyclone body.
    Pergunte ao FixBot
    Comentar
  10. Dyson DC58 Cyclone Replacement: passo 10, imagem 1 %32 Dyson DC58 Cyclone Replacement: passo 10, imagem 2 %32
    • Pull down on the black tube-like part of the silver cyclone body to remove it from the cyclone of the Dyson.
    • You may need to wiggle the tube as you are pulling down to loosen the pieces apart.
    Pergunte ao FixBot
    Comentar
Conclusão
22 outras pessoas executaram este guia.
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Membros
Autoria de 24 guias
11Comentários do guia
Great job, very useful thanks
Don - Responder Compartilhar
Fantastic thanks!!!!
robh - Responder Compartilhar
Very helpful indeed.
macx - Responder Compartilhar
Thanks. Had to wash out the dog smell. This did the trick.
David Parsons - Responder Compartilhar
Thanks. Had to wash out the dog smell. This did the trick when new filters wouldn't. Shame on Dyson for not making an easier to clean vacuum.
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 115
Ao todo: 28,485
