Ir para o conteúdo principal
Dyson DC58 Battery Pack Replacement
O que você precisa
  1. Dyson DC58 Battery Pack Replacement, Bin: passo 1, imagem 1 %32
    • Make sure your vacuum is unplugged.
    • Avoid pressing the red trigger on the vacuum handle; this will power on the vacuum.
    Pergunte ao FixBot
    Comentar
  2. Dyson DC58 Battery Pack Replacement: passo 2, imagem 1 %32
    • Locate the red lever parallel to the red trigger and on the side of the clear bin.
    Pergunte ao FixBot
    Comentar
  3. Dyson DC58 Battery Pack Replacement: passo 3, imagem 1 %32
    • Push the red lever downward to open the clear bin. You may need to do this over a trash bin if there is debris in the clear bin.
    Pergunte ao FixBot
    Comentar
  4. Dyson DC58 Battery Pack Replacement: passo 4, imagem 1 %32 Dyson DC58 Battery Pack Replacement: passo 4, imagem 2 %32
    • Push the red lever downward again while pulling the clear bin away from the main body of the Dyson vacuum.
    Pergunte ao FixBot
    Comentar
  5. Dyson DC58 Battery Pack Replacement, Battery Pack: passo 5, imagem 1 %32 Dyson DC58 Battery Pack Replacement, Battery Pack: passo 5, imagem 2 %32
    • Locate the 10mm screw on the side of the battery pack closest to the purple cyclone of the vacuum
    • Use the 2.0 Phillips head screwdriver to remove the 10mm screw
    Pergunte ao FixBot
    Comentar
  6. Dyson DC58 Battery Pack Replacement: passo 6, imagem 1 %32 Dyson DC58 Battery Pack Replacement: passo 6, imagem 2 %32
    • Locate the 10mm screw on the back of the handle on the opposite side of the red trigger button
    • Use the 2.0 philips head screwdriver to remove the 10mm screw
    Pergunte ao FixBot
    Comentar
  7. Dyson DC58 Battery Pack Replacement: passo 7, imagem 1 %32 Dyson DC58 Battery Pack Replacement: passo 7, imagem 2 %32 Dyson DC58 Battery Pack Replacement: passo 7, imagem 3 %32
    • Pull the base of the vacuum down, away from the main body
    Pergunte ao FixBot
    Comentar
Conclusão
62 outras pessoas executaram este guia.
Krista St Onge
Membro desde: 09/17/15
2.260 Reputação
Autoria de 2 guias
Equipe
CSU Fullerton, Team 2-4, Bruce Fall 2015 Membro de CSU Fullerton, Team 2-4, Bruce Fall 2015
CSUF-BRUCE-F15S2G4
4 Membros
Autoria de 24 guias
19Comentários do guia
I paid just £30 for a black & decker dust buster 10yrs ago & you tell me you want £60 for a replacement battery pack after 3yrs. Dyson has to do better. Your records don’t show that you agreed to replace the pack while the product was under gaurantee so this battery isn’t even 2yrs old!
lucialucia21 - Responder Compartilhar
Great illustration.
apple - Responder Compartilhar
mine isn;’t even a year old
M Donahue - Responder Compartilhar
Yup we have three stain animals in our house two are just over one year old and the other is a little over two years. None of them hold a charge anymore
swelch19673 - Responder Compartilhar
Had a dyson V8 Animal a little under two years and already needing a new battery.
Think I will go back to using a corded machine which lasts a lot longer and costs a lot less to buy. Sorry dyson but I’m not impressed.
Doug Mummery - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 45
Últimos 30 dias: 239
Ao todo: 202,050
