Ir para o conteúdo principal
Dyson DC39 Origin Pre-filter Replacement
    1. Dyson DC39 Origin Pre-filter Replacement, Bin: passo 1, imagem 1 %32 Dyson DC39 Origin Pre-filter Replacement, Bin: passo 1, imagem 2 %32 Dyson DC39 Origin Pre-filter Replacement, Bin: passo 1, imagem 3 %32
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      Pergunte ao FixBot
      Comentar
    1. Dyson DC39 Origin Pre-filter Replacement, Pre-filter: passo 2, imagem 1 %32 Dyson DC39 Origin Pre-filter Replacement, Pre-filter: passo 2, imagem 2 %32 Dyson DC39 Origin Pre-filter Replacement, Pre-filter: passo 2, imagem 3 %32
      • Remove the purple pre-filter by pulling it up and out of the bin.
      Pergunte ao FixBot
      Comentar
Conclusão
Luke Matusiak
Membro desde: 04/26/17
491 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team S23-G6, Livingston Spring 2017 Membro de Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 30
Ao todo: 4,497
