Ir para o conteúdo principal
Dyson DC39 Origin Ball Wheels Replacement
O que você precisa
    1. Dyson DC39 Origin Ball Wheels Replacement, Bin: passo 1, imagem 1 %32 Dyson DC39 Origin Ball Wheels Replacement, Bin: passo 1, imagem 2 %32 Dyson DC39 Origin Ball Wheels Replacement, Bin: passo 1, imagem 3 %32
      • Push down on the gray button located next to the power button to release the bin from the ball housing.
      • Pull the bin away, then up from the ball housing to remove it.
      • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
      Pergunte ao FixBot
      Comentar
    1. Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: passo 2, imagem 1 %32 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: passo 2, imagem 2 %32 Dyson DC39 Origin Ball Wheels Replacement, Steering Assembly: passo 2, imagem 3 %32
      • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
      • Remove the four 18.0 mm Torx 15 screws.
      Pergunte ao FixBot
      Comentar
    2. Dyson DC39 Origin Ball Wheels Replacement: passo 3, imagem 1 %32 Dyson DC39 Origin Ball Wheels Replacement: passo 3, imagem 2 %32 Dyson DC39 Origin Ball Wheels Replacement: passo 3, imagem 3 %32
      • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
      • Hold the steering assembly base near one of the wheels.
      • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
      • Push up on the steering assembly to remove it completely from the ball housing.
      • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
      Pergunte ao FixBot
      Comentar
    1. Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: passo 4, imagem 1 %32 Dyson DC39 Origin Ball Wheels Replacement, Ball Wheels: passo 4, imagem 2 %32
      • Remove the 21.4 mm Torx 15 screw located at the center of the ball wheel.
      • There is one screw located at the center of each wheel.
      Pergunte ao FixBot
      Comentar
    2. Dyson DC39 Origin Ball Wheels Replacement: passo 5, imagem 1 %32 Dyson DC39 Origin Ball Wheels Replacement: passo 5, imagem 2 %32 Dyson DC39 Origin Ball Wheels Replacement: passo 5, imagem 3 %32
      • Pull the wheel away from the main body of the device.
      • This may require a lot of force. The plastic wheel may bend slightly.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S23-G6, Livingston Spring 2017 Membro de Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 28
Ao todo: 2,656
