Ir para o conteúdo principal
Dyson DC39 Origin Replacement
O que você precisa
  1. Dyson DC39 Origin  Replacement, Bin: passo 1, imagem 1 %32 Dyson DC39 Origin  Replacement, Bin: passo 1, imagem 2 %32 Dyson DC39 Origin  Replacement, Bin: passo 1, imagem 3 %32
    • Push down on the gray button located next to the power button to release the bin from the ball housing.
    • Pull the bin away, then up from the ball housing to remove it.
    • If the bin won't fit back into place during re-assembly, you may need to push the grey button again.
    Pergunte ao FixBot
    Comentar
  2. Dyson DC39 Origin  Replacement, Steering Assembly: passo 2, imagem 1 %32 Dyson DC39 Origin  Replacement, Steering Assembly: passo 2, imagem 2 %32 Dyson DC39 Origin  Replacement, Steering Assembly: passo 2, imagem 3 %32
    • Place the ball housing on its side and orient it so that the underside of the steering assembly is facing you.
    • Remove the four 18.0 mm Torx 15 screws.
    Pergunte ao FixBot
    Comentar
  3. Dyson DC39 Origin  Replacement: passo 3, imagem 1 %32 Dyson DC39 Origin  Replacement: passo 3, imagem 2 %32 Dyson DC39 Origin  Replacement: passo 3, imagem 3 %32
    • Using two hands, hold the ball housing with the handle in one hand and the steering assembly base in the other.
    • Hold the steering assembly base near one of the wheels.
    • Pull the steering assembly base directly away from the ball housing. You should notice a pin release.
    • Push up on the steering assembly to remove it completely from the ball housing.
    • During reassembly, slide the steering assembly in first, then push the pin back into its locking position.
    Pergunte ao FixBot
    Comentar
  4. Dyson DC39 Origin  Replacement, Inlet Hose: passo 4, imagem 1 %32 Dyson DC39 Origin  Replacement, Inlet Hose: passo 4, imagem 2 %32
    • Remove the two 17.8 mm Phillips #2 screws located in the top of the inlet hose bracket.
    • Remove the two 13.7 mm Torx 8 screws located at the opposite end of the inlet hose.
    • The Torx 8 screws are located at an odd angle. Be sure the screwdriver is secure to prevent stripping the screws.
    Pergunte ao FixBot
    Comentar
  5. Dyson DC39 Origin  Replacement: passo 5, imagem 1 %32 Dyson DC39 Origin  Replacement: passo 5, imagem 2 %32
    • Pull the inlet hose straight up from the steering assembly.
    • The inlet hose 'snaps' out of its position, so you may have to apply a little extra force while pulling.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S23-G6, Livingston Spring 2017 Membro de Cal Poly, Team S23-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G6
3 Membros
Autoria de 6 guias
1Comentário do guia
Really clear instructions - thank you
collette - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 10
Últimos 30 dias: 26
Ao todo: 4,771
