Ir para o conteúdo principal
Dymo LabelManager 280 Keyboard Replacement
O que você precisa
    1. Dymo LabelManager 280 Keyboard Replacement, Rear Case: passo 1, imagem 1 %32 Dymo LabelManager 280 Keyboard Replacement, Rear Case: passo 1, imagem 2 %32
      • Remove battery.
      • Remove the label cassette.
      Pergunte ao FixBot
      Comentar
    2. Dymo LabelManager 280 Keyboard Replacement: passo 2, imagem 1 %32 Dymo LabelManager 280 Keyboard Replacement: passo 2, imagem 2 %32
      • Remove the two rubber feets
      • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
      Pergunte ao FixBot
      Comentar
    3. Dymo LabelManager 280 Keyboard Replacement: passo 3, imagem 1 %32 Dymo LabelManager 280 Keyboard Replacement: passo 3, imagem 2 %32
      • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
      • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
      Pergunte ao FixBot
      Comentar
    1. Dymo LabelManager 280 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Dymo LabelManager 280 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32
      • Remove the rubber keyboard.
      Pergunte ao FixBot
      Comentar
Conclusão
Steven Nguyen
Membro desde: 02/08/16
431 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 6-5, Eyestone Spring 2016 Membro de USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Membros
Autoria de 27 guias
1Comentário do guia
thank god the bottom feet are not glued in. and the tabs are not difficult
Edward Wijntuin - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 1,437
