Introdução
If your charging port has become unresponsive or loose, it may be time for replacement or adjustment. This guide provides step-by-step instructions on how to access and replace the charging port.
O que você precisa
Use wire cutters or scissors to cut the wires attached to the charging port, and remove the charging port.
Solder the black wire to the bottom-most node of the new charging port. Solder the red wire to the uppermost node of the new charging port. See the following link for soldering tips: Como soldar e dessoldar contatos
Uma outra pessoa concluiu este guia.
