Introdução
Use this guide to replace a defective battery LED indicator from your Durofix RV332. A new battery LED is need to complete this repair.
O que você precisa
Remove the six 13 mm case screws with a #0 Phillips screwdriver from the side of the power screwdriver.
Uma outra pessoa concluiu este guia.
Um comentário
Hello, I would ask the author about the type and model number of the electronic element marked as Q1 on the PCB (transistor or thyristor) on the third picture in Step 3 of this article, because mine is burnt out, and on this picture can't be read anything.
Greetings,
Plam
