Ir para o conteúdo principal
DualShock 4 CUH-ZCT2 Rear Panel Replacement
O que você precisa
  1. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel screws: passo 1, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel screws: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
    Pergunte ao FixBot
    Comentar
  2. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Separate the rear panel: passo 2, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Separate the rear panel: passo 2, imagem 2 %32
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
    Pergunte ao FixBot
    Comentar
  3. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: passo 3, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: passo 3, imagem 2 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Release the plastic clips: passo 3, imagem 3 %32
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
    Pergunte ao FixBot
    Comentar
  4. DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel: passo 4, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement, Remove the rear panel: passo 4, imagem 2 %32
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. DualShock 4 CUH-ZCT2 Rear Panel Replacement: passo 5, imagem 1 %32 DualShock 4 CUH-ZCT2 Rear Panel Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
    Pergunte ao FixBot
    Comentar
Conclusão
6 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
99.125 Reputação
Autoria de 290 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 30
Últimos 30 dias: 191
Ao todo: 6,296
