Introdução
Follow this guide to replace the front case, also called a front panel or shell, in your DualShock 4 model CUH-ZCT1U controller.
O que você precisa
Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
Ferramenta utilizada nesse passo:Microfiber Cleaning Cloths$3.99
Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
Use an opening pick to pry each corner of the L1 button from the front case.
Remove the button.
Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
Slide your pick toward the handle and pry up to release the first clip.
Repeat this procedure on the other side of the controller to release the second clip.
Grab and remove the reset button extension from its recess in the battery bracket.
Locate the two clips securing the battery bracket to the motherboard.
Insert the point of your spudger into the opening behind the right bracket clip.
Depress the clip to disengage it from the motherboard.
Lift up the right edge of the battery bracket.
Ferramenta utilizada nesse passo:Tweezers$4.99
Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
Use tweezers or your fingers to disconnect the cable using its blue pull tab.
Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
Grab the midframe by its plastic protrusions or the vibration motors and remove it.
Remove the Share and Options buttons from the front case.
Remove the three silicone button pads from their buttons in the front case:
The squared off pad for the directional pad
The rounded pad for the action buttons
The small pad for the home button
If you wish to remove the silicone button pads for the touch pad, Share, and Options buttons, follow this step. Otherwise, continue for the standard set of buttons.
Remove the directional pad, action buttons, and home button from the front case.
Lift the bottom edge of the touch pad.
Rotate the touch pad and slide it through its cutout in the front case to remove it.
You're now left with the front case.
32 outras pessoas executaram este guia.
Um comentário
As of March 14, 2023, this guide has been updated! Comments regarding step procedures may no longer be relevant.
