O que você precisa
First, check that the connection port of your controller (whether wireless or not) has all the pins.
If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may reconnect broken connections within the controller cable and could be a temporary fix.
48 outras pessoas executaram este guia.
7Comentários do guia
Dualshock 2 controllers, model A and H, are having 8 pins, not 9. Your first Step is false and rarely wires are the cause of the problem.
No my Dual-shock 2 controller has 9 pins so you are wrong he is right man.
Eva Langley is correct, some of these controllers have only 8 pins, not 9. I myself can conformed this because I just recently opened one of two brand new fresh out of the box Sony original equipment controllers that I purchased (for a little less than $10 a piece) during a clearance sale at my local Sears just before they went out of business. So Eva is NOT wrong. I still have the second one still in the box and before anyone ask, I don’t won’t to sale. I purchased them because I have had both my original controllers go out after they were sitting up for a few years without use. My game units are very well taken care of but the controllers of the PS2 just stopped working and finding a definitive answer to why this happens is STILL very elusive in 2019.
After opening one of these, the R2 and L2 buttons don't feel right, is there a way to fix this?
Try to put R2 and L2 after you close the shell. The buttons have clips that hold on position after you insert them .
