Introdução
Follow this guide to replace the vibration motors on a Sony PlayStation 5 DualSense controller.
This guide requires desoldering and soldering the vibration motor wires.
Note: This guide is for DualSense controllers with an FCC ID ending in 1. Check the back of your controller to verify your model. If yours ends in A, there will be differences in the internal design.
O que você precisa
Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
Lift the middle trim over the joysticks to remove it.
Insert the flat end of a spudger into the gap above the L1 button.
Pry upward to remove the L1 button.
Insert the flat end of a spudger into the gap above the R1 button.
Pry upward to remove the R1 button.
Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
Carefully guide the joysticks through the front case and lift the motherboard out.
Flip over the controller and motherboard.
Use a soldering iron to desolder the vibration motor wires from the motherboard:
Two red wires
Two black wires
Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
Apply high concentration isopropyl alcohol (90% or greater) to the vibration motors through the openings in the bottom of the midframe.
Allow the isopropyl alcohol to soak for one minute to dissolve the adhesive securing the vibration motors to the midframe.
Uma outra pessoa concluiu este guia.
