Ir para o conteúdo principal
DualSense Controller v2 Middle Trim Replacement
O que você precisa
  1. DualSense Controller v2 Middle Trim Replacement, Unclip the right end of the middle trim: passo 1, imagem 1 %32 DualSense Controller v2 Middle Trim Replacement, Unclip the right end of the middle trim: passo 1, imagem 2 %32
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 1 %32 DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 2 %32 DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 3 %32
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Middle Trim Replacement, Unclip the left end of the middle trim: passo 3, imagem 1 %32 DualSense Controller v2 Middle Trim Replacement, Unclip the left end of the middle trim: passo 3, imagem 2 %32
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 1 %32 DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 2 %32 DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 3 %32
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: passo 5, imagem 1 %32 DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: passo 5, imagem 2 %32 DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: passo 5, imagem 3 %32
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
Conclusão
3 outras pessoas executaram este guia.
Sam Omiotek
Membro desde: 02/25/19
92.525 Reputação
Autoria de 290 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 54
Ao todo: 1,599
