Introdução
Follow this guide to replace the L1 and/or R1 buttons on your Sony DualSense controller.
Note: This guide is for current DualSense controllers with FCC IDs that end with A. Check the back of your controller to verify your model. If yours ends in a 1, it is an early model and there will be internal differences. Follow these guides for the earlier version.
O que você precisa
Insert the flat end of a spudger into the gap above the L1 button.
Pry the spudger upward to remove the L1 button.
Insert the flat end of a spudger into the gap above the R1 button.
Pry the spudger upward to remove the R1 button.
3 outras pessoas executaram este guia.
1Comentário do guia
The "reassemble" isn't the steps in reverse order. Cmon now
