Ir para o conteúdo principal
DualSense Controller V5 Touchpad Replacement
O que você precisa
  1. DualSense Controller V5 Touchpad Replacement, Unclip the right end of the middle trim: passo 1, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Unclip the right end of the middle trim: passo 1, imagem 2 %32
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller V5 Touchpad Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Unclip the lower-right edge of the middle trim: passo 2, imagem 3 %32
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller V5 Touchpad Replacement, Unclip the left end of the middle trim: passo 3, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Unclip the left end of the middle trim: passo 3, imagem 2 %32
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller V5 Touchpad Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Unclip the lower-left edge of the middle trim: passo 4, imagem 3 %32
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller V5 Touchpad Replacement, Remove the middle trim: passo 5, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the middle trim: passo 5, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Remove the middle trim: passo 5, imagem 3 %32
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. DualSense Controller V5 Touchpad Replacement, Remove the L1 button: passo 6, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the L1 button: passo 6, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Remove the L1 button: passo 6, imagem 3 %32
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. DualSense Controller V5 Touchpad Replacement, Remove the R1 button: passo 7, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the R1 button: passo 7, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Remove the R1 button: passo 7, imagem 3 %32
    • Repeat the previous step to remove the R1 button.
  8. DualSense Controller V5 Touchpad Replacement, Remove the rear case screws: passo 8, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the rear case screws: passo 8, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller V5 Touchpad Replacement: passo 9, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 9, imagem 2 %32
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller V5 Touchpad Replacement, Separate the rear case: passo 10, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Separate the rear case: passo 10, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Separate the rear case: passo 10, imagem 3 %32
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. DualSense Controller V5 Touchpad Replacement: passo 11, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 11, imagem 2 %32 DualSense Controller V5 Touchpad Replacement: passo 11, imagem 3 %32
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. DualSense Controller V5 Touchpad Replacement: passo 12, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 12, imagem 2 %32 DualSense Controller V5 Touchpad Replacement: passo 12, imagem 3 %32
    • Repeat the previous step on the right edge to release its clips.
  13. DualSense Controller V5 Touchpad Replacement: passo 13, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 13, imagem 2 %32
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. DualSense Controller V5 Touchpad Replacement, Remove the rear case: passo 14, imagem 1 %32
    • Remove the rear case.
  15. DualSense Controller V5 Touchpad Replacement, Disconnect the battery: passo 15, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Disconnect the battery: passo 15, imagem 2 %32
    • Don't try to fully remove the battery, as it's still connected to the controller by delicate cables.
    • Swing the battery out of its recess so you can access its connector, making sure to not strain the cables.
    • Keep the battery supported so it doesn't fall during the next step.
  16. DualSense Controller V5 Touchpad Replacement: passo 16, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 16, imagem 2 %32 DualSense Controller V5 Touchpad Replacement: passo 16, imagem 3 %32
    • Use a pair of angled tweezers to firmly grip the short sides of the battery connector.
    • To get a stronger hold on the connector, grip the tweezers as close to the connector as you can.
    • Rock the connector side‑to‑side to walk it out of its socket and disconnect it.
  17. DualSense Controller V5 Touchpad Replacement, Remove the battery: passo 17, imagem 1 %32
    • Remove the battery.
  18. DualSense Controller V5 Touchpad Replacement, Remove the lower microphone: passo 18, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the lower microphone: passo 18, imagem 2 %32
    • Use tweezers to grip the lower microphone cable's plastic tab and pull it straight out of the socket to remove the microphone.
    • During reassembly, make sure the microphone has its rubber gasket and that the alignment tab goes into its cutout.
  19. DualSense Controller V5 Touchpad Replacement, Remove the battery bracket: passo 19, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the battery bracket: passo 19, imagem 2 %32
    • Use a Phillips screwdriver to remove the 6.5 mm‑long screw securing the battery bracket.
  20. DualSense Controller V5 Touchpad Replacement: passo 20, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 20, imagem 2 %32
    • Remove the battery bracket.
  21. DualSense Controller V5 Touchpad Replacement, Disconnect the motherboard: passo 21, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Disconnect the motherboard: passo 21, imagem 2 %32
    • Use tweezers to grip the hard plastic section of the right trigger ribbon cable and pull the cable straight out of its socket to disconnect it.
    • If you're having trouble, try gripping the tweezers as close to the cable as possible to get a better hold.
  22. DualSense Controller V5 Touchpad Replacement: passo 22, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 22, imagem 2 %32 DualSense Controller V5 Touchpad Replacement: passo 22, imagem 3 %32
  23. DualSense Controller V5 Touchpad Replacement, Reposition the motherboard: passo 23, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Reposition the motherboard: passo 23, imagem 2 %32
    • Throughout the rest of your repair, be very careful not to strain the delicate wires attached to the bottom edge of the board. They can easily tear, requiring soldering to fix them.
    • Use your fingers to gently push the joysticks through their cutouts on the shell to separate the motherboard.
  24. DualSense Controller V5 Touchpad Replacement: passo 24, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 24, imagem 2 %32
    • Carefully flip the motherboard down so the joysticks are facing up.
  25. DualSense Controller V5 Touchpad Replacement, Remove the speaker: passo 25, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the speaker: passo 25, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Remove the speaker: passo 25, imagem 3 %32
  26. DualSense Controller V5 Touchpad Replacement, Remove the midframe: passo 26, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the midframe: passo 26, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Remove the midframe: passo 26, imagem 3 %32
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the midframe.
  27. DualSense Controller V5 Touchpad Replacement: passo 27, imagem 1 %32 DualSense Controller V5 Touchpad Replacement: passo 27, imagem 2 %32 DualSense Controller V5 Touchpad Replacement: passo 27, imagem 3 %32
    • Carefully lift the midframe and motherboard up and out of the front case.
  28. DualSense Controller V5 Touchpad Replacement, Touchpad: passo 28, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Touchpad: passo 28, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Touchpad: passo 28, imagem 3 %32
    • Swing the bottom of the touchpad up and away from the controller to remove it.
    • During reassembly:
    • Insert the touchpad through the back of the case and hook the top edge into place.
    • Make sure the touchpad cable doesn't get trapped between the case and the touchpad.
    • Push the bottom edge of the touchpad firmly into place, making sure the circular alignment posts snap into place and are sitting flush in their cutouts.
    • Check the front edge of the touchpad and make sure the thin strip of plastic on the front shell isn't wedged under the touchpad. If it is, remove the touchpad and reinsert it so the thin strip is parallel to the touchpad.
  29. DualSense Controller V5 Touchpad Replacement, Remove the touchpad: passo 29, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the touchpad: passo 29, imagem 2 %32
    • Use your fingers to push down on the front of the touchpad until it detaches from the shell.
    • You should feel and hear a "click" as the touchpad detaches.
  30. DualSense Controller V5 Touchpad Replacement, Remove the touchpad screw: passo 30, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the touchpad screw: passo 30, imagem 2 %32
    • Use a Phillips screwdriver to remove the 6.5 mm‑long screw securing the touchpad.
  31. DualSense Controller V5 Touchpad Replacement, Remove the touchpad: passo 31, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the touchpad: passo 31, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Remove the touchpad: passo 31, imagem 3 %32
    • The touchpad is secured to its bracket by two clips—a circular one that snaps into place, and a rectangular one that slides into place.
    • Use your fingers to pull up the left side of the touchpad to unclip it.
    • Slide the right side of the touchpad out from its clip and remove it.
    • If your replacement touchpad doesn't come with a cable installed, transfer the one from your original touchpad to the new one.
  32. DualSense Controller V5 Touchpad Replacement, Remove the Options and Create buttons: passo 32, imagem 1 %32 DualSense Controller V5 Touchpad Replacement, Remove the Options and Create buttons: passo 32, imagem 2 %32 DualSense Controller V5 Touchpad Replacement, Remove the Options and Create buttons: passo 32, imagem 3 %32
    • Use tweezers or your fingers to remove the Options and Create buttons.
Conclusão
Uma outra pessoa concluiu este guia.
Spencer Day
Membro desde: 09/14/22
149.721 Reputação
Autoria de 995 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.629 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 22
Últimos 30 dias: 127
Ao todo: 801
