Ir para o conteúdo principal
Drill Master Heat Gun Motor Replacement
O que você precisa
    1. Drill Master Heat Gun Motor Replacement, Motor: passo 1, imagem 1 %32
      • Be sure the heat gun is unplugged before starting this process.
      • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
      • You will need a screwdriver extension.
      Pergunte ao FixBot
      Comentar
    2. Drill Master Heat Gun Motor Replacement: passo 2, imagem 1 %32
      • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
      • Don't try to open the casing just yet.
      Pergunte ao FixBot
      Comentar
    3. Drill Master Heat Gun Motor Replacement: passo 3, imagem 1 %32 Drill Master Heat Gun Motor Replacement: passo 3, imagem 2 %32 Drill Master Heat Gun Motor Replacement: passo 3, imagem 3 %32
      • Remove the barrel casing on either end by twisting and pulling each side off.
      Pergunte ao FixBot
      Comentar
    4. Drill Master Heat Gun Motor Replacement: passo 4, imagem 1 %32
      • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
      Pergunte ao FixBot
      Comentar
    5. Drill Master Heat Gun Motor Replacement: passo 5, imagem 1 %32
      • Remove the metal casing and fan cover from the fan unit.
      Pergunte ao FixBot
      Comentar
    6. Drill Master Heat Gun Motor Replacement: passo 6, imagem 1 %32
      • Bend the metal prongs backward that connect the fan motor to the plastic cap.
      • Bending the brackets too far back can cause the brackets to break.
      Pergunte ao FixBot
      Comentar
    7. Drill Master Heat Gun Motor Replacement: passo 7, imagem 1 %32
      • Remove the plastic cap from the motor,
      • This will allow you to work only with the motor and fan.
      Pergunte ao FixBot
      Comentar
    8. Drill Master Heat Gun Motor Replacement: passo 8, imagem 1 %32
      • Remove the fan by pulling it from the motor rod.
      Pergunte ao FixBot
      Comentar
    9. Drill Master Heat Gun Motor Replacement: passo 9, imagem 1 %32
      • Remove the two 12mm screws from the plastic fan casing using PH#00
      Pergunte ao FixBot
      Comentar
    10. Drill Master Heat Gun Motor Replacement: passo 10, imagem 1 %32
      • Remove the plastic fan casing.
      Pergunte ao FixBot
      Comentar
    11. Drill Master Heat Gun Motor Replacement: passo 11, imagem 1 %32
      • Remove the metal casing from the motor and insert the new motor in its place.
      • You may have to tug a little.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
1Comentário do guia
Where can I find a new motor?
jstabler38 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 46
Ao todo: 2,366
