Ir para o conteúdo principal
Dremel 8220 Power Switch Replacement
O que você precisa
    1. Dremel 8220 Power Switch Replacement, Power Switch: passo 1, imagem 1 %32
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      Pergunte ao FixBot
      Comentar
    2. Dremel 8220 Power Switch Replacement: passo 2, imagem 1 %32
      • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
      Pergunte ao FixBot
      Comentar
    3. Dremel 8220 Power Switch Replacement: passo 3, imagem 1 %32
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      Pergunte ao FixBot
      Comentar
    4. Dremel 8220 Power Switch Replacement: passo 4, imagem 1 %32
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Dremel 8220 Power Switch Replacement: passo 5, imagem 1 %32 Dremel 8220 Power Switch Replacement: passo 5, imagem 2 %32 Dremel 8220 Power Switch Replacement: passo 5, imagem 3 %32
      • Remove five T9 Torx screws from the side of the tool.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      Pergunte ao FixBot
      Comentar
    6. Dremel 8220 Power Switch Replacement: passo 6, imagem 1 %32
      • Remove the faulty power switch. It should come out of the device without using any force.
      Pergunte ao FixBot
      Comentar
Conclusão
4 outras pessoas executaram este guia.
Equipe
1Comentário do guia
Awesome!! Thanks!
christooher t - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 20
Últimos 30 dias: 49
Ao todo: 2,652
