Ir para o conteúdo principal
Dremel 8220 Gear Lock Button Replacement
O que você precisa
    1. Dremel 8220 Gear Lock Button Replacement, Gear Lock Button: passo 1, imagem 1 %32
      • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
      Pergunte ao FixBot
      Comentar
    2. Dremel 8220 Gear Lock Button Replacement: passo 2, imagem 1 %32
      • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
      Pergunte ao FixBot
      Comentar
    3. Dremel 8220 Gear Lock Button Replacement: passo 3, imagem 1 %32
      • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
      Pergunte ao FixBot
      Comentar
    4. Dremel 8220 Gear Lock Button Replacement: passo 4, imagem 1 %32
      • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
      Pergunte ao FixBot
      Comentar
    5. Dremel 8220 Gear Lock Button Replacement: passo 5, imagem 1 %32 Dremel 8220 Gear Lock Button Replacement: passo 5, imagem 2 %32 Dremel 8220 Gear Lock Button Replacement: passo 5, imagem 3 %32
      • Remove the 5 torx screws using a t9 screwdriver head.
      • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
      Pergunte ao FixBot
      Comentar
    6. Dremel 8220 Gear Lock Button Replacement: passo 6, imagem 1 %32
      • Remove the faulty gear lock button. It should come out of the device easily with no force needed.
      Pergunte ao FixBot
      Comentar
Conclusão
connor anisko
Membro desde: 03/09/16
312 Reputação
Autoria de 2 guias
Equipe
3Comentários do guia
I’m assuming the issue I have is a faulty gear-lock button (that, or the locking gear that it restricts when depressed). If so, did you find a replacement button from the manufacturer? In my experience, they rarely offer repair parts themselves.
Robert - Responder Compartilhar
I also don’t understand why there was a flag claiming that this should be broken into separate guides. People aren’t THAT stupid, I hope.
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 47
Ao todo: 1,385
